1 - 3 of 3 Posts
Discussion Starter #1
I'm trying to a I-Spec B shifter to an I-Spec A brake lever and running into a problem. It seems like I'm missing a part I need and I'm trying to identify the correct kit. I've seen these 2:
https://www.bikeparts.com/BPC427323...aewBUdEk3seIa9qxjIxtSXI8X6tZ9i6BoCC-IQAvD_BwE
https://www.nashbar.com/shimano-bol...jHttm_7w5yBfkbfOYUzh5oUdslkuH1khoCJ4kQAvD_BwE
Has anyone done this before? It seems like if I had the deep threaded nut on to the left side on either of these kits it may work. I should have just bought a shifter with a clamp which I may just do.
I did the same, but I had your 1st link which was holding the old i-spec b mount to the shifter. So i took off the i-spec b mount and used the "INTEGRATION BOLT UNIT". So if you do not have it, you 1st link is what i used.
My xt shifter comes with the INTEGRATION BOLT UNIT, the slx shifter is very different and you would need the part. Not sure as it does not look like INTEGRATION BOLT UNIT would work with the slx.
SLX
https://www.google.com/imgres?imgur...hUKEwjM1ry94ensAhVEIt8KHdsZDEcQMyhHegUIARDkAQ
XT
https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcTwqY8OKqqzEXv09jxIjCE4CLgVoy8CC6uKpQ&usqp=CAU
Discussion Starter #3
Thanks! My shifter came with everything you see in the first link except for the threaded nut with the square top that's on the left side in the second link. The bolt on the right is the same in both links just different colors but I have that as well. I just need something for that bolt to thread into. So you used the threaded nut in the first link at bikeparts.com with your i-spec a brakes and b shifters?
1 - 3 of 3 Posts
