I put 3wt oil in my F100X and like it much better.
I was hating the Terralogic. It would not activate easily enough for technical climbing and felt like it had more stiction than an old Mag20 or RS1 on easier trails, even with the threshold a minimum and 52 psi (I weight 150, 160 with gear).
I put in Bel Ray 3wt (12.6 centistoke) [stock FOX is ~31 centistoke, 7.5 wt.]
If you take the brain cartridge out you will note a small orifice at the top of the cartridge, this orifice is always open and allows the fork to reach sag without the inertial valve being activated and allows the fork to move a bit without the inertial valve being activated. I was hoping that lighter weigth oil would move through this orifice more easily and make it less of a kick when the fork first hits a bump before the inertial valve stays open.
Yes the fork is more plush now and when climbing a rough gravel road the fork now moves for 2 cm diameter pebbles (Stock Fox or 125/150 Golden Spectro - 7 wt oil would not allow the fork to move unless I first did a little wheel lift to shock open the brain).
The fork does bob more for rough pedalling, but rough pedalling will make a road bike with 100psi in the tires bob anyway (learn to pedal and you will be way more efficient than imagining no suspension will make you go faster).
The notchiness between open and closed valve is much less now.
An added benefit, before when using 52 psi the negative spring was sucking in 20mm of my travel, then with 20 to 25 mm of sag, I only had 55 - 60 mm of travel). Now I am able to pump up to 70 to 72 psi and still get the plushness I want and lose only 5 mm to the negative spring.
I was doing some 2 foot drops to flat concrete, landing with wheels level, and still had about 3 to 5 mm of travel left over (using 72 psi). At 60 psi I was using all my travel on a very rooty downhill with no big drops (just lots of little ones) but never felt the shock bottom out.
PS the Fox maintenance schedule might seem extreme (I think it says overhaul your fork every 50 hours) but I noticed it didn't even take that long before that Golden Spectro fork fluid was discoloured and dirty looking (where does the dirt come from anyway?, I'm using Enduro Fork Seals now and haven't seen a drop of oil or lost any air - the stock Fox seals were worse than the Exxon Valdez)
