1 - 20 of 34 Posts
Drinking the Slick_Juice
i think im finally going to cut my vertical droputs and weld out some horizontal dropouts.
where can i get some pre-made horizontal sliding dropouts or just regular ones?
Couldn't you cut some off another frame. Seems like it would be easier to just get another frame. With vertical drop outs, I assume you are stock with what ever gear combo is tight enough, eh? That is what I'm wondering.
Discussion Starter · #3 ·
well all my other frames have crappy ones, and i dont want to buy another frame because the one i have is awesome, u may have seem it(trek 850)
but im not going to cut off the vertical dropouts on the 850 , first im going to test it out on my haro.
Surly lists their dropouts on their website. If it were up to me I would probably go for an ENO eccentric hub. Cleaner, easier, maybe cheaper?
I'd have no problem chopping and welding my Trek 950. It isn't as nice looking as your bike, but it is a lugged frame. I'll have to check out this Surly dropouts.
Discussion Starter · #7 ·
well i don't know if those Ebbs work on Euro bbs, it probably would be cheaper.i really don't know how those work. but don't worry about the cost im in a welding class at my high school and my teacher would let me use the school equipment.
one chain loop
the process is not as easy as you think it is. go eno or the new ebb from forward components and save yourself from hassle.
Retro Grouch
Here's a picture of some Surly "track ends", used to be called sub 11's. There about $30 @ pair (half the price as Paragon non-sliders). If you want to see more I did a blog entry to describe the surgery. Bonty Blog
You can buy them @ Harris Cyclery
There's no need to cut and weld a frame you like. You can use a set of Excentrikers.
Then if you don't like it, you can flog them on eBay. They're not cheap, but it would probably work out cheaper than the frame job.
ernesto_from_Wisconsin said:
get an ENO hub :)
or that too :)
i am a welder by trade and have a problem with welding on bikes.
1st you need to know the material grade.
2nd by pumping heat into your bike you can weaken the material or make it harder and then find cracks.
3rd the EBB sounds like a better option.
Hmm Brad,
Arent those dropouts designed to be welded more "into" the chain and seatstay? Is there some reasoning behind this setup?
Also I am very intrested in the crankset on the flyer beneath the frame. What is it? Is see some wierd splines on the bracket axle. Care to give me some info?
@ OP: Maybe it is easier to solder the dropouts. That way you pump less heat into the frame which might be better for the material. When you get some of those sub11 dropouts you can just cut the chain and seatstay where they should be place. Some filing and brazing should do the trick. And use some old axle as an alignment rig.
DiDaDunlop said:
...Also I am very interested in the crankset on the flyer beneath the frame. What is it? Is see some weird splines on the bracket axle. Care to give me some info?...
Standard Campagnolo Ultra Torque Road cranks, nothing special.
"@ OP: Maybe it is easier to solder the dropouts. That way you pump less heat into the frame which might be better for the material. When you get some of those sub11 dropouts you can just cut the chain and seatstay where they should be place. Some filing and brazing should do the trick. And use some old axle as an alignment rig."
Brazing is an art form, especially if you have never done it before. It looks a lot easier than it actually is. It's very difficult to accomplish correctly...
Webcyclery has the Surly track ends. Unless you really know WTF you're doing, may be better to go with the Eno eccentric hub:).
Discussion Starter · #19 ·
i have no idea how those ENO hubs work, they do seem kinda expensive. if i screw up its going to be on an inferior frame. i will extensively test the test frame ;) . ill have to go to the forest's of The Woodlands and ponder this decision . i was also thinking about an eccentric bottom bracket , i somewhat understand how those work.
Retro Grouch
DiDaDunlop said:
Hmm Brad,
The track ends were installed by Paul Sadoff of Rocklobster so I trust his experience and judgement (he doesn't do this modification anymore so please don't ask).
1 - 20 of 34 Posts
