Damn, I'm getting frustrated... As much as I love the stopping power and on-th-fly adjustability, I hate that screeching/squaling noise every time I tough the brakes!
I know if the calipers aren't aligned properly with the rotors, you get mad squealing.
For starters, these pads are relatively new and genuine AVID pads. I've cleaned the pads and rotors and rinsed down everything (no soap or detergents). I then took fine-grit sandpaper (like 220 or something) and lightly rubbed the rotors and pads. I then installed the brake calipers. Hopefully this is right: tighten the pads against the rotors first and then tighten the bolts on the calipers to the frame and then dial the pads away from rotors according to personal brake lever pressure (using Avid SD5 levers).
My pads seem to have uneven wear (probably because I didn't align them properly the first time around several months ago)... Could this be the problem? If you guys agree that I've installed these properly and it must be the uneven pads, can I get away with using another less expensive brand of pads? Damn, those AVID pads are pretty expensive!
