And for that matter where the heck has Grumpy been?
(NO offense to other knowledgeable brake posters!)
Anyways, i've got a project i'm thinking about (again) and I need further education if I want to make it work well. I want to make a mechanical disc brake caliper and I want it to be LIGHT. I have two big problems with this project and i'll just have to figure one of them out on my own, but the other - i'm sure I can find an answer here.
The problem i'm looking for more information on is with regards to heat dissipation, particularly with the caliper. What I believe I know correctly is that if you have a caliper with greater mass (more weight) you have a caliper that can not only absorb heat better, but also dissipate it better than one that has less mass. Is this correct or just poor assumption on my part?
Also, if it is correct, then should this not also mean that if you make a caliper "too light" that some heat dissipation properties it posesses would also be affected ..... even to the point of poor brake performance?????
I'm not an engineer and don't know everything, but I need input on this particular issue to decide if I want to try to tackle "problem #2".
All/any help that is based on fact (just the facts ma'am) is greatly appreciated.
PATIA!
PATIA!
