to pack this bad boy in... My old case from my 26" S&S MTB will not work unless I remove the tires, oh well... I am still working out fit and contact point issues so cockpit may change but so far this is what I have come up with. I'd like a bar with more sweep and still work with the Rohloff shifter ok. I may try a Mary again.
A little heavey but with WB & Rohloff I guess that is to be expected. I really like the cable routing for the Rohloff, very clean. Next time you see her there will be several less Moots decals...
Anyone else used a Thomson S-2 stem on a MTB? It is the only 31.8 stem my LBS had on hand that had the reach and ~rise I wanted. I assume it will be ok but if not let me know while I still have my teeth.
JK
JK
