1 - 20 of 30 Posts
nashbar.com
Right now you can get 20% off and they have the Diamondback Overdrive 29er which would be $440 after the 20% discount. There's also a rigid singlespeed on there which is even cheaper, but I'm assuming you want a suspension fork.
The Duuude, man...
I have some parts and peices you could have cheap.
Monocog frame/fork
BB7 brakes (no rotors or levers)
Surely front wheel (like new)
Handle bar
That's a bit shy of a full happy meal though.
Missouri sucks...
My buddy has the Overdrive 29er and other than the seat/seatpost/brake levers has been a REALLY good bike for him! He's 6'6", 280' so he's pretty hard on stuff so you may be ok with the before mentioned parts...
Currently in Exile
Banned
Frozenspokes said:
We are in danger of this becoming the BikesDirect forum. But, where else you gonna send someone with only $500 to spend.
Yes , unless you buy used they pretty much own this price point .
Is dang happy!
seatpost is fine..
No problems with wtb seat or brake levers either. The dart forks on that model can have a defective damper that leaks and the rear freehub is not quite "shimano" quality but for the price the overdrive is a good bike. At 280 he should be crushing most bike parts.
Missouri sucks...
He actually broke the rail on the seat:eek: Not from being adjusted wrong or anything either! The rails came loose in the back of the seat. I was almost like the epoxy, or whatever they use, came loose. The brake levers are still working but they have a TON of play and have a flimsy feel to them. It's not my bike but if it was I'd be picking up a set of cheap Avid 5 levers off ebay for $15... The seat post isn't broken but it creeps BAD! He tried an old bolt clamp he had, instead of the QR clamp, and it still creeps. I'm sure that has a lot to do with being a big dude, though. It's a sweet bike for just over $400 though! I'd get one if I had a budget:thumbsup:
I was in the same situation with my wife. She wanted a new bike but only wanted to spend 500 bucks, but I went ahead and got the Windsor Cliff29 PRO for $699. You get alot of nice upgrades(fork, brakes, dereailers, etc.) that is well worth the extra $200.
Feeling retro..but Jung
really
bikewrench said:
I have an 18" OnOne Scandal frame that I would let go pretty cheap. It's the original Scandal w/ vertical drops and the scandium front end.
How Much??
A good product with solid support in my opinion.
I'm a little shorter and a little heavier. I ride an Overdrive. I am also a noob. It was a good bike stock, way better than the 10 year old Fisher that I started with. Not light, but neither am I.
I broke the frame above the weld cluster at the tt/st. I got the wrong size (L) to begin with, and put a longer Thompson setback post in to accommodate. They replaced it with an XL and I am way happy with the bike now after some upgrades. I have had other failures, but I would have had them on any other "cheap" 29er too I am sure. Cheap hubs and 300+ pound noobs will never get along.
My lbs has been helpful, friendly, and supportive the whole way. I don't know what help you would get from an online dealer though. Dicks sporting goods moves them cheap at the end of the year, if you have one in your area. I would say for any "cheap as possible " bike it is worth spending a few more bucks locally to get some warranty support. It may as well be a Wal-Mart special if you can't get support to repair and maintain it. If you were talking more in the 1500 plus range, I would say get it on line as cheap as you can.
Discussion Starter · #20 ·
Thanks, everyone for the insight. I spoke to my LBS and he seemed to think the 2010 Outcast SS would be a pretty good choice. I ike the DB Overdrive, but I am weirdly jonesing for a SS... I haven't ridden in a looooong time, but somehow the SS thing really interests me. BTW, seems like NOBODY ever has a used XL or even L 29er for sale. I'm 6'4" and about 225 lbs. I did see a DB Overdrive on Amazon shippe for $405... I just don't know.
1 - 20 of 30 Posts
