1 - 4 of 4 Posts
Had to replace the brake hose on a Shimano 525. But now I cannot get the air out of the system. To be honest I think I cannot get any oil into the system. There appear a few tiny air bubbles in the reservoir but the level of oil never changes...
How do you get oil into an empty hose? The bleeding information on Shimano's website is useless. I follow to the point - but it doesn't work.
HELP
Klaus
Feeding your addiction
HELP
Klaus
Hey Klaus. Yeah, sometimes with empty hose it's difficult to get it initially flowing in. If you have a syringe, push fluid in from the bottom to fill the hose, then you should be able to follow the normal bleed procedure. If you don't have a syringe then just make sure you open the bleed nipple a lot and tap on the hose and caliper with something to try and get it started. If that doesn't work, feel free to drop by the shop tomorrow afternoon and I can give you a hand.
Larry
Mountain High Cyclery
[email protected]
Discussion Starter · #3 ·
Larry,
thanks syringe did the trick. That and tons of pumping. My 525 is ready to go. But I also need to bleed my Magura Gustavs. Do you happen to have a bleed kit for those? They seem to require back bleeding and I don't have the nipple for the caliper. Also: I am very low on mineral oil now.
Klaus
Kaba Klaus said:
Larry,
Klaus
Can't say that I've ever actually had to bleed Gustav's but I think they use the same bleed kit as their other brakes, I do have that and some fluid.
Larry
1 - 4 of 4 Posts
