First of all, I have a disease. It's a sickness. When comparison shopping, I have to rank products against each other numerically. I don't know why, but I do know it's not normal. I mean, I get pretty in depth and make up complex formulas in Excel to see how Product A ranks against Product B in a bunch of different categories. It's pretty borderline obessive, but it helps me make a decision.
I am NOT showing you the spreadsheet I made, you guys would think I'm insane. I'll give you the gist of what I did to come up with my results. I'm not ranking overall performance per se, but the value - what you get for the money.
Price
I found the lowest LOCAL prices for as many bikes as I could find. Otherwise, I used the MSRP listed on the manufacturer's website. I tried to pick bikes that I could get locally and then added some internet only bikes to compare. Also, I chose bikes based on their everyday price, not a closeout or sale price.
If the bike was an online order only, I added $50 for shipping (except the Ibex, only $35 for shipping) and $50 for professional assembly. I figured any bike you get from your LBS is going to be professionally assembled, so to make it even, ALL bikes have to be assembled bike a real bike tech.
Sales tax is not included either.
Weight
This one was kinda tough. Some websites list an actual weight, I had to search for the weight on some bikes and I had to make an educated guess on others. Weights are not 100% accurate but the weight actually mattered the least in the rankings, because all the bikes are fairly close in range. I'm not comparing a 20 lb bike to a 50 lb bike.
Components
I used the following for comparisons:
Fork
Front derailleur
Rear derailleur
Shifters
Disc brakes
I figured these components were the ones that would have the greatest impact on how the bike rides...and I didn't feel like taking the time to research anything else. On the disc brakes, I didn't compare different brands against each other or against V-brakes, I awarded a point based on if the bike came with discs or not. The only reason I did that was for the sake of future upgradeability - forks, wheelsets, better disc brakes, etc.
Points system
This is where I'm going to seem like a lunatic with too much time on his hands (actually I've been unemployed for 3 months,so I do have too much time to do stuff like this).
The components were ranked as:
1 point for bottom of the barrel
2 points for acceptable entry level
3 points for decent entry level
There's 4 categories with 3 points available in each and then discs brakes are an additonal 1 point, for a total of up to 13 points.
Weight: the lightest bike was awarded 10 points, with other bikes receiving a percentage based on its weight.
Price: same thing, the cheapest bike was awarded 10 points, with other bikes receiving a percentage base on its price.
Here are the results:
24.00 points - Forge Sawback 5xx ($419.99)
23.81 points - Ibex Alpine 550 ($654)
23.54 points - Gary Fisher Marlin (non disc) ($589.99)
23.18 points - Iron Horse Warrior 1.3 ($350)
22.33 points - Trek 4500 ($579)
21.77 points - Specialized Rockhopper (M4 frame) ($519.99)
21.53 points - Kona Blast ($649)
21.51 points - Cannondale F7 Disc ($499.99)
21.16 points - Giant Yukon ($499.99)
20.62 points - Cannondale F6 ($529.99)
20.50 points - Felt Q620 ($599.99)
20.32 points - Trek 4300 Disc ($599.99)
19.30 points - Specialized Hard Rock Comp Disc ($509.99)
The Ibex and Kona are over the $600 cap, but I threw them in just to compare. And I bet you could probably find the Kona for $600 if you looked hard enough. I had to draw the line somewhere and I wasn't going to go up to $700, then $750 and so on.
Cheapest bike - Iron Horse Warrior 1.3 - $350 after pro assembly
Most expensive bike - Ibex Alpine 550 - $654 after shipping/pro assembly
Best bike you can actually buy in a shop - Gary Fisher Marlin (non-disc)
Best components - Gary Fisher Marlin, Ibex Alpine 550
Lightest bike - Ibex Alpine 550 - 28 lbs.
So there you have it. Since the Warrior 1.3 is so cheap, it kinda skews the results. It really is pretty weak component-wise, but because it has the lowest price by far, it fares well against better bikes. The Hard Rock Comp Disc comes out to be the worst value. Similarly equipped to the Warrior 1.3, but it costs $160 more.
I've read stuff here and there regarding the questionable quality of Forge's frame for the Sawback. Since I really have no way of measuring that, it wasn't included in the comparison. Same thing with resale value - Trek is a name people recognize, Iron Horse probably is not. That might be part of the decision in purchasing a bike, but it can't be quantified in any way.
My system isn't perfect and my numbers may not be 100% accurate, but at least it serves as a general guideline. At least I now know which bikes I'm definitely not going to buy. Hopefully this info will help some of you guys out too.
Price
Weight
Components
Fork
Front derailleur
Rear derailleur
Shifters
Disc brakes
Points system
