I bent my seatpost....
639 Views 3 Replies 3 Participants Last post by  bigdamo
but it is quite common with the Truvativ xr post according to reviews.
What I need to know is it ok to use a 27.2 post in my 04 Hollowpoint. It came with a 27.0
but I have a 27.2 and it slid in without forcing it. It is a bit snug but I did no more than twist it a few times to get it in.
For the record my post was not exposed beyond the minimum, it has about an inch of space before it hits the min line.
1 - 4 of 4 Posts
_hamilton said:
What I need to know is it ok to use a 27.2 post in my 04 Hollowpoint. It came with a 27.0 but I have a 27.2 and it slid in without forcing it. It is a bit snug but I did no more than twist it a few times to get it in.
I'm using a 27.2mm Thomson post with my '04 Hollowpoint. I know (from reading past posts) that a number of other folks are using 27.2mm posts too. If you wind up using a 27.2mm post, just make sure that you grease it well so that it doesn't get stuck.
thanks for the info
I will grease it good.
1 - 4 of 4 Posts
