A few things.
1. I do run them FR at times. ForeKaster 2.35s are very low volume, so you would definitely need the 2.6. The knobs are the only thing that gets them to 2.35 width. Where as a Schwalbe 2.35 is large. The MM, NN and HD all measure around 62mm on a 35mm rim at the casing. I also rarely pinch flat one unless I make a huge line choice error at full DH race pace. They are always fixed in a minute with a dynaplug even is split at the rim.
The IKON 2.35 tires is absolutely massive on the other hand, and has been unbelievably reliable and hard to flat because the volume and TPI.
2. There is a tendacy to overtire and then this tendency to over protect. You can be a tire killer who rides bad lines, or a heavy lander (often line choice) or you may have a different style where you dance around and skip over the tops of rocks with ease. Being from Houston, I wouldn't expect you to be an expert at central Texas lines, but who knows.
I don't like these comments about needing exo+ or DD casing, from They also don't ride as well as 120 tpi casing in the rocks.
That weight limit is total BS. Inflate your tires properly. At the end of the day, you must get the tire that matches your skill or lack there of in handling a bike and tendency to take bad lines. Or just run more PSI. How many of folks religiously set psi to the half psi at the trail head? It changes 2 psi transitioning from indoors to a warm outside, or a 120 degree garage to a 95 degree outdoor ride. That psi is enough to get massive rim strikes and pinch flats.
Now IF you are racing enduro at the pointy end, you can't afford any flat. There is your use case.
Full disclosure, I have pinch flatted more foreKasters than any other tire. It has caused me to DNF one race and cost me 10 minutes in another marathon. All of these instances were due to me underinflating the tires a bit. The DNF I flatted at 40 mph and didn't see I had 3 holes Until I was completely through all of my C02. I rarely ever have any issue
Dynaplug For the win! If you aren't racing, you fix it and are on your way. We retired my wife's last nobby nic on her enduro with 12 plugs.
I have probably spent the most amount of miles on a nobby nic/Nobby nic combo. I have rarely had any issue with flats. They seem to be better with rim strikes and line mistakes than the foreKaster. So I am also tempted to try a 2.6/2.6 Nobby Nic on a ripmo build as well. It's tough, because the ForeKaster has slightly more absolute cornering grip In central Texas, but not in all soils.
3. I would just ride max speed all around. The dual is a 60tpi casing and the max speed is 120
We buy tires in bulk from here:
https://www.bike-discount.de/en/buy...t-tr-exo-3c-maxxspeed-120-folding-tyre-886412
Our last box of 16 tires got stuck in customs due to COVID?, but other than that have arrived promptly.
