1 - 2 of 2 Posts
I accidentally pulled my front break lever while it had the front tire off and now that front pad is much closer to the rotor and rubs it, not to mention I barely have to pull the lever now. I have the Shimano M485, hydraulic disc brakes, 160mm rotors, is this an easy fix? If so, how?
Super Moderator
just use a clean screwdriver, and put it between the pads and spread them apart..... if the pads are not on the brake, use something softer like a plastic tire lever to spread the pistons..
1 - 2 of 2 Posts
