i'm spec'ing out a setup for a new xc race bike and need a little help. i've narrowed it to two brake/shifter combinations:
1. magura marta sl levers and calipers and sram x0 triggers.
2. xtr 965 integrated brake/shifters w/ xtr calipers
weights for the magura setup are pretty easy to figure out from the weightweenies site:
345g for front lever/hose/fluid/caliper/rotor/bolts
361 for rear
224 for both shifters (no cables)
i can't seem to figure out how much a compable (levers/hose/fluid/calipers/bolts/rotor) xtr setup would weigh. anyone have good info on that?
barring real numbers, does anyone have a sense that one setup would have a clear weight advantage over the other? by how much?
thanks much.
361 for rear
thanks much.
