1 - 7 of 7 Posts
I have a 2006 Rockhopper Comp Disc. The bike came with Avid BB-5 mechanical disc brakes, and I'm upgrading to Avid hydraulics.
My frame only has two cable/hose guides on the toptube. These guides are "open faced" like hydraulic hose guides (i.e. they're not standard cable stops), but they're not slotted at the bottom for zip ties.
In stock configuration, the mechanical brake cable is routed through flanged inserts that slip into the guides and act as cable stops (see attached picture... sorry for the low quality). Does anyone know where to find a similar insert that works for securing hydraulic lines to these guides?
I've already talked with my local dealer, and they were at a loss (their suggestion was that I dremel slots into the base of the guides for zip ties... something I'd rather avoid).
Help is appreciated.
--MW
Discussion Starter · #4 ·
oldskoolbiker said:
If you don't want to dremmel it out, take a look at these items:
http://www.pricepoint.com/detail/12562-050_PRMHB3-3-Parts-49-Cables/Cable-Guides.htm
Yeah, I've seen both options. The bolt-on style requires a standard, slotted cable stop (which I don't have); the stick-on style might be an option if I can't find a better solution... but honestly, it seems silly to _not_ use the hose guides that are already on the frame.
Can't figure out why Specialized made this so weird.
--MW
Discussion Starter · #5 ·
XSL_WiLL said:
There are little grommets that fit around the hose. They really don't work all that well. But if you can't find them, drop me an email. I'll send a couple out.
Hey, cool. I'll follow up with you on this... my dealer doesn't have anything for me, and I haven't found "the right part" after three evenings of Google'ing for it.
Just out of curiosity, why don't they work very well?
--MW
Meh.
They're too loose; they tend to slide out from where they were. A bit of electrical tape works much better. Wrap it around the hose and slide the fattened portion through the guide. Zipties work great too.
Discussion Starter · #7 ·
Yeah... I ended up just using a wrap of electrical tape in front of each guide. Totally inelegant, but it gets the job done. Still gotta say, though, it was pretty lame of Specialized to not slot the guides for zip ties.
Thanks for the suggestions.
--MW
1 - 7 of 7 Posts
