A lot of time and engineering goes into bump stop specification and shape on coil over suspension systems. This is true for cars and motorcycles but also bicycles. Arguably, a properly specified bump stop is going to be a more simple to use and cheaper to implement setup then an HBO setup.
Obviously, the folks at EXT know what they are doing, but so do the folks at push. From the position of needing to fit several frames and shock sizes, it's a safer bet to use a closed cell foam that's specified to add the progressiveness and bottom out resistance characteristics that you want.
It is very inconvenient to utilize this sort of system in a fork, but very convenient to use this sort of system in a shock. This is why you will always see more physical bump stop bumpers then HBO systems in rear shocks.
TLDR, don't under estimate the thought that goes into that little foam puck on your coil shocks. Also, take note that when you buy a DHX, you're getting one choice of bottom out bumper, which is another reason to go with something like the 11/6 over an off the shelf aftermarket shock.
P.S. if learning more about bump stop materials and shapes is interesting to you... there is a ton of information in the motorsports world about this, specifically stock class autocross racing. Many times when you can't change the shocks bodies and springs out, the only mechanic you are left with is internal valving and bump stop bumpers. I spent a ton of my early motorsports career learning what length, shape and density worked best for the ride heights I was running on my stock class miata.
example -
Automotive Suspension Experts | Fat Cat Motorsports, Inc. | Bump stop application guide
