Any preliminary reports on the Hutchinson Bulldog tires that are coming stock on a lot of the 2005 Jamis bikes?
Do a search of Bulldog in the Wheel and Tire forum. You see a few there. These are still pretty new so there is not a lot of info out there as far as feedback. I for one really like mine so far. Keep in mind that the sizing runs small. I understand this is a tendancy of Hutchinson tires in general. The claimed 2.1 is actually a 1.95.justwright03 said:Any preliminary reports on the Hutchinson Bulldog tires that are coming stock on a lot of the 2005 Jamis bikes?
Stopped by the LBS to drop off some rims for repair and saw the bulldogs. They remind me of the new Panaracer Cinders. They have a staggered square block tread, with the center of some treads dug out. They are not deep lugged, but look like they will perform great in varying conditions. They do run skinnier than stated on the tire. It looks like a 1.95 rather than a 2.1. They should clear mud OK and the dug out treads will assist with roots and rocks.justwright03 said:Any preliminary reports on the Hutchinson Bulldog tires that are coming stock on a lot of the 2005 Jamis bikes?
I ran the tires at 32 front and 35 rear air pressure Friday on a hardpack trail that was damp to dry, but not dusty dry- if you know what I mean. Even through the damper areas the tires never got squirrely on me. I beginning to like the tires. Low pressure is the best bet with these!!!HPilot said:Well, the Bulldogs do well on damp or wet soil. So far, I do not feel confidence enspiring handling when on dry hardpack (with a loose soil cover), sandy or gravel sections. I am not running the front at the recommended competition psi of 29, so that may have something to do with it. Also, I am still playing with fork pressure and bump sensitivity. I have a 100mm stem with a 680mm handlebar (which is way too long), so that may have a bearing on handling feel. I do know that the front tire has almost washed on me several times, but I felt it and was able to recover. It just seems that I can't lean as much as with my Panaracer Fire XC Pro and still carve a corner. Other handling issues may be coupled with the whole bike. It's not my Ferarri hardtail that I'm used to. I may opt to throw a set of Cinders on, or buy another set of the Fire XC's.
Overall, the Bulldogs are a large volume tire, so they may appear to be 1.95 in tread width, but have bulky sidewalls that give them the ability to be run at 29 psi without pinch flats. I may try to air down a bit and see how it goes.
