Maybe I missed it, but it doesn't look like you've mentioned which rim this is on. I'm guessing it is narrower than a hundie, since that is considerably less width than I measured....?How did you make these measurements? Mine are not going to be as precise as yours, especially if we don't measure things with the same method but here's what I got for the Surly Nate tire anyhow. I'll measure up my Endomorph and Larry a bit later. I just used my digital calipers and a long metric yardstick to estimate these. Also, I hear the tire sizes within a given type (Nate, BFL, Endo) vary a bit (or a lot) with the Surly tires. I've noticed that each of my fatbike tires has at least a little warble in it (not the rim, but the tire itself).
Surly Nate 26" x 4.0":
Tread width = 96mm
Casing width = 97mm
Diameter = 734mm
Rim edge to top of tire tread = 80mm
axle to widest point of tire sidewall = between 315 - 345mm.
I know this is obvious for most but I'll write it anyhow since I didn't really 'get it' until i did it once: That last measurement is what helps me figure out where to place the bend in the chainstays and how much to dimple. The overall wheel diameter helps me with BB height and drop and figure out how long the chainstays need to be so that the wheel clears the seat tube since i don't bend the ST yet.
I forgot to mention it. I have the Rolling Darryl rims (82mm wide).Maybe I missed it, but it doesn't look like you've mentioned which rim this is on. I'm guessing it is narrower than a hundie, since that is considerably less width than I measured....?
