1 - 20 of 59 Posts
Fo' Bidniz in da haus
Since the preponderance of techy measure...weigh...and graph everything toolz reside on the Turner forum, an easy question no doubt....what is the weight difference between a rear King HD w/ fun bolts hub versus non-HD w/ skewer setup? Doubt its much (guessing ~50 grams) but wanted to check.
Outcast
just re-enforce your garage wall, and you won't have to worry about your bike falling off of it due to it's never ridden weight.
Discussion Starter · #3 ·
it is true, as noted in other threads, Turner homers are very mean-spirited. I came here to seek your wisdom and you mock me
i may need to ask in the Ibis forum
Outcast
It is true, as noted in this forum, that homer mean-spiritedness has caused the weak-minded to purchase other brands of bikes.
The answer to your question is......Cleveland.
Discussion Starter · #8 ·
try this...amongst the banter, which is as useful i agree...please throw in a response to my answer, b!tches
Discussion Starter · #13 ·
rroeder said:
Have you considered the ignore feature?
I should have asked on socaltrailriders.org...they are very not mean-spirited and i would have received a hug along with the answer
I don't do PC
and a thanks!
Bite Me.
I weighed both items on my digital scale - but now I forget. Hope that helps.
Discussion Starter · #17 ·
thanks for an almost answer...probably the best i am going to get it appears
see if i do anything ever again for the homers
Discussion Starter · #20 ·
celluloid hero said:
stainless driveshell adds 48g
funbolts add 42g
thanks! dude, you may now lose membership amongst your homer colleagues!
as for the weight gain, sounds trivial then. While funn bolts weigh 42 grams, a skewer weighs at least that much so there is no gain from the bolts.
thanks again and everybody else can go eff themselves
1 - 20 of 59 Posts
