I recently bought a marzocchi bomber dj for a dirt jumper. The spacing is 20x110. What kind of hubs/wheels can work with this? Can I run a 15x100 wheel or do I need to get different hub caps? Thanks
Can I use a 15x100 wheel and put on different endcaps?A 20mm axle will not fit into a 15mm hub.
Depends on the hub. I had older Hope ProII's that would switch between 9mmQR/15mm/20mm thru axle. But again, all hub dependent.Can I use a 15x100 wheel and put on different endcaps?
