1 - 4 of 4 Posts
I am going to attempt my first hub overhaul and need some poniters. The hubs are bontrager race -non disk hubs from a race UST tubeless wheelset. I just bought them on Fleabay, and the seller neglected to mention the bearings were marginal.
Here are the questions:
1. How do I identify my specific hubs so I can order the right parts? The freehub body has "BKP" stamped in the splined area.
2. Where is a good place to buy bearings for bontranger hubs?
3. Is a bearing press really required, or has anyone successfully rigged up their own press for the job? Normally I am pretty crafty with creating my own specialty tools, but I don't want to damage anything unwitttingly.
4. How can I tell if the freehub body needs replacement, and if it does...where do I get one?
If it helps, I can post some pictures
D
No idea about this hub.
Try Boca bearings, they have extensive manufactures lists. That said it may not be accurate.
If I didn't need the bike for a couple of weeks I would strip it down and remove the bearings and measure them to check with Boca (somebody else metioned VXB).
For my mavics, I use a small flat punch and my tiny ball peen and tap them out. (easy and maybe 30 secs.
To reinstall I use my big Ball Peen ball end resting on the bearing and tap with the little one till it seats, (easy 30 secs.).
I do use a little Moly Disulphide assemble grease as well.
I ordered bearings for my Hopes from Phil Wood.
To get the old bearings out I used a big flat blade screwdriver and hammer- which totally destroyed the old bearings.
To press the new ones in, I used some threaded rod, washers, and a got a small length of PVC pipe that fit the OD of the new bearings.
1 - 4 of 4 Posts
