Warp2003 said:
I know all of that... that's what I referred to with "in patents things just have to be different enough"... I know Manitou actually patented the TPC... not sure about the older Zokes and RS's.
If lubrication is a fault of TPC... why Marzocchi went that way with TST?? They also called Manitou crazy about their Post mounts for brakes...
OTOH, I'm happy to see some standarization.
Simple, manitou never really embraced "open bath" damping, and the most they ever got was a little oil sloshing down in there in the most recent models, and whether or not it really gets up on the legs I have to wonder about. Marzocchi on the other hand has had open bath damping and the legs get constant lube, which is the same with the AM1, the 40cc of oil in the TST leg lube the legs and bushings, but the real thing here is that marzocchi has been using seals that KEEP oil IN the fork, even under extreme pressures. This is where the other companies have not really been able to compete, and why the "air assist" effect of the marzocchis is such a good thing.
The "lubrication" fault of the TPC was that it had to be "microgreased" with the grease ports, and once the grease made it's way away from the surface it was trying to protect, it would just pack up somewhere in the fork and become inneffective. The "evil genius" seals came a little later, and that was a step in the right direction, but for the longest time they didn't run any oil for lube, relied on grease, and that grease system did not constantly slosh oil on the tubes as marzocchis "open bath" did.
The benefit (as you pointed out somewhere else I believe) is that the oil remains much more cleaner. When I changed the oil in my X-vert it was green, so it looked brand new after about a year of use. TPC also combined this with a pretty large oil volume (at least for a closed damper).
The other thing about open bath though is cooling, and more circulation should lead to more cooling and keeping certain parts from overheating, it may not be a huge concern, but it kind of works like the oil in our airplanes, it circulates to not only lubricate, but to cool and suspend particulates, so it serves a bunch of purposes.
This isn't supposed to be a marzocchi-love-fest post, but TPC+ did a lot of things right, Good volume of oil, the floating piston made it very supple initially (like a marzocchi) and it had a shimmed-piston setup (like the cartridge marzocchis, but just with a different arrangement). The only places where it lacked was in the usage of materials (plastic) and lubrication.
If you want to break down TPC even further, it's just a different arrangement of pistons as compared to a normal cartridge-fork, and cartridge forks were around for a long time before TPC, so TPC simply "arranged" the pistons differently, wasn't really working any differently, just looked different and arranged different.
