Hey all,
I've got a bizarre howling noise coming from my rear Hayes Mag. I have all linkage and brake mount bolts torqued correctly, I've messed around with the angle of the caliper and it seems perfect, I've cleaned the rotor and the pads are relatively new Galfer reds. It will howl for about ten seconds, really loud, and then fade away if I keep on the brake hard. Yesterday I took my pads out to have a look and noticed that 1) One piston is a little farther out than the other, even though they both move freely, and 2) one piston has a small chunk missing from it. Could this missing bit of piston be causing some weird vibration and hence the howl?
Thanks for any advice!
-Andy
-Andy
