1 - 20 of 34 Posts
I read about GPS ability to track backing and log track. Does it allow user to create the trail he went through earlier? Can he retrace his route? I check website but it doesn't explain how backtrack.
Yes and yes, assuming about 100 different things. If you get a cheap- GPS it will tell you what direction to go to get to your waypoint. A better GPS will mark a trail as you travel, an even better one will mark the trail, and tell you how to stay on it. The real nice ones will not only mark you trail, but also save it, show you the profile, download to the computer, and a whole slew of other neat features. If you really want to get geeky (ahem...like me....) you can create your own maps and place them on the GPS. You can also load software onto them to have the GPS tell you where you are, and when to turn to get where you are going. In addition, you can buy software that will tell you where the closest Chinese food is, how far, and how to get there from your current position.
I don't like the cheap ones, I usually know what direction the car/camp is, but I might not know HOW to get there. Having a trail is a real nice feature, imo. I prefer Garmin, you can't make your own maps for Magellin, but they have a lot of nice feaures also.
Discussion Starter · #3 ·
which garmin do you use?
How did you create your own map? did you use topo map? Which garmin do you use? I like the 60CS with external antenna and colour screen. I am a geek too. I like to play around with the software. I will buy it when tax refund come back.
I have the 60, I think that series is the best out there right now, but I will only use Garmin due to their compatibility and custom mapping abilities. I can also plug my Garmin into my laptop and capture the real-time GPS feed.
Making uploadable maps requires quite a few steps and multiple software. I use ArcGIS at home and work, and it's mostly cost prohibitive for most people, you can also use OziExplorer. You will also need cGPSMapper and SendMap. If you do some googling you will find several sites that do step-by-step instructions.
To whet your appetite, you can create transparent topos that will overlay on roadmaps etc. You can then add your own trails on the topos and make them routable so that your GPS will tell you when a turn is coming. Nice stuff.
the Garmin 76 is about the same thing, but has more memory and floats. I prefer the smaller 60 myself.
Edit: all the software you need is available free on the web. The guys that write this stuff are in it for fun and can be very helpful. Enjoy!
Discussion Starter · #5 ·
Is ARC GIS a commercial software? How reliable is Garmin GPS? Does it get good signals under tree canopy ?
Discussion Starter · #6 ·
memory shortage with all features downloaded ?
With all this software download to the garmin GPS, doesn't overload memory? How do you deal with this problem?
I've not overloaded the memory. If you are concerned with it, you can just load the maps you want/need for the trip and leave the rest on you computer. You can also turn maps on/off within the GPS if youi have more loaded than you need.
ArcGIS is a spatialdatabase. It's like driving a semi-truck to the store for a carton of eggs, for what you need. I make maps on it and I'm very used to it, but it is very expensive. OziExplorer does the same things (for what you would need) and is free, and more intuitive for the unexperienced.
Basically you need to [1]get some maps, [2]georeference them (tell them where they fit on the globe using Ozi) and [3]convert them to the proper format for Garmin(cGPSMapper), [4]then load it to the GPS (SendMap). I have only made simple maps for myself as of yet, I'm in grad school and getting behind so the geek-play is on the back burner.
All the maps (topos and road) files are also available online from gov't agencies for free. I know people also make routable maps themselves, but that is mostly for out-of-country maps, why bother when you can shell out less than $100 and get the whole US on a CD from Garmin? I'm all for geek-stuff, but I have my limits.
Also, if you just want topos you can buy a 1:250,000 topo CD from Garmin, but that's not good enough resolution for me. You can also buy better resolution maps, but only of the National Parks. I don't believe these maps are transparent either, so they will replace any road maps you have of the area. The entire nation at 1:250,000 will fit on the GPS at once, so memory is not really an issue, imo.
Discussion Starter · #8 · (Edited)
grad school ?
Basically you need to [1]get some maps, [2]georeference them (tell them where they fit on the globe using Ozi) and [3]convert them to the proper format for Garmin(cGPSMapper), [4]then load it to the GPS (SendMap). I have only made simple maps for myself as of yet, I'm in grad school and getting behind so the geek-play is on the back burner. All the maps (topos and road) files are also available online from gov't agencies for free. I know people also make routable maps themselves, but that is mostly for out-of-country maps, why bother when you can shell out less than $100 and get the whole US on a CD from Garmin? I'm all for geek-stuff, but I have my limits.
What are you studying in grad school ? Aren't you tired of school ? I finish my bachelor and I was exhausted, burned out. I slept for 2days straight. I didn't want to look at another text book.I am also disenchanted with employers outhere whom do not value a formal education. A degree from any school is considered toilet paper to them. Of all employers whom I had work in the past, none of them value education. It's consider as driver license. Most managers, CEO don't have formal education. They are arrogant as hell.
Rarely found outside AZ
Very Cool
I am also a map maker that mountain bikes. I have been using GIS for the past 9 years. I just recently got back into Mountain Biking and carry a GPS on occasion (when I can borrow one from work). I have a software package at work called Expert GPS that enables me to download the route from the GPS unit into a shapefile. I can then display the route over topograhic maps and aerial photography. Not that it helps me on the ride much, but I enjoy seeing the route in relation to the topographic features that are on the maps and aerials.
Glad to know there are other GIS Geeks that are mountain bikers.
Discussion Starter · #10 ·
me geek too !
Hi saguaro, its nice to meet other geeks here too! Phewww. i thought I am all alone in this world. They might lock me up in white pad room and throw the key away. I wonder how many geeks out there are also MTB riders. :D
hehe
well, I don't consider myself a geek in general, but others may disagree with me. When it comes to mapping and GIS I can be kind of a geek. If I am talking about mapping and GIS, most people don't uderstand me, so I feel like like a geek in those circumstances.
No, no, no...
You guys have this all wrong! If your going to be a geek, take the ball and run with it! I think it's cool that I have more electronic gizmos on the handlebar of my bike than I have in my car. If I could feel safe with my laptop opened across the handlebar on a trail, I'd probably try it out too. Grad school in Civil Engineering, at least it isn't Electrical Engineering (you can't speel geek without EE!!).
saguaro, do you use Arc version 9? You can create a shapefile of your track on a laptop in realtime with their new GPS toolbar. The toolbar is kind of a watered down version, but you can also download ArcPAD and have a TON of GPS features. Get the free version and you have to save and exit every 15 minutes, but you get full functionality. Full version is like $800 :eek:
A friend of mine created maps from shapefiles of all the new lots for sale in a subdivion and used his 60CS to find the lots, then explore the exact boundaries as they were not staked well. Made shopping for a new house fun, and geeky I guess.
Discussion Starter · #13 ·
hey mapping biker, do you think the 60CS is more rugged than the 76CS, new model ? The 76CS doesn't have external anntena thus I am concerned that it may not receive strong signal as the 60CS.
ArcGIS 8.2
Actually I am still on Version 8.2. The company I work for hasnt had the funding to upgrade to the current version. It is gonna cost us over $15,000 to upgrade, so they have been a little hesitant. But I am hopefull it will happen this year.
I don't have any personal experience with the 76. I understand they have the exact same antenna, but on the 76 it is under plastic. The 76 is also lined with foam to make it float, and I wonder if that also makes it more shock-resistant, but again, no experience.
They both take an external antena if that turns your crank. Some guys mount a small external to their helmets and run the cable down to the GPS, either in a backpack or on the bars(!!!). I'm not sure I like the idea of my head being tied to the bars myself...
Discussion Starter · #16 ·
is it necessary to record waypoints?
Do I need to enter a waypoint everytime I reach a crossroad on a trail or the Garmin records it on track log? How do you do record your route when you ride the trail? Can you describe it to me?
I have a 76s that works really well for me, however I am holding out for something in color now with removeable memory, on the trails it's not a big deal but making tracklogs and following them in conjested areas is nearly impossible in the monochrome screens. I'm also holding out for garmin to do something similar to the 60/76 in color with a memory card feature. I'm sure they are holding back because memory restrictions are one of the big reasons people buy new gps's so if you put memory cards in them people are probably not going to buy new ones as often. The 76 is also pretty big on the bars, I've actually toyed with the idea of getting a cheaper etrex unit to keep on the bars that would be a smaller package, and more expendable. I also concidered the foretrex unit, but it has no base map, and the more expensive units run only on an internal rechargeable battery (bad for trips).
It's always good to see other arcGis users. Though I agree with what other's have said, at least for this kind of use ArcGis is total overkill and if you could buy a couple top line mountain bikes for what it costs non-educational pricing.
However it is fun, I've been toying with doing a arcscene fly by of a trail, off of NED and areial data, however it's proving to be way too intensive for a little 3ghz desktop to toy with at least at the resolutions I'd like, so it's been sidelined for now.
I've used trackmaker, and such before with a lot of success. In fact that's what I used to make tracklogs of the trails in moab, off of their east/west maps. I was surprized how accruate they were out in moab, easily close enough to keep you on the trail, and give you a very good idea where you were going.
The garmin gps's have what they call a tracklog feature, you can get to your trail head, start the tracklog and it will basically take data as you move and compose that into a tracklog. This data can then be saved, and reversed in order that you can follow it back to the trailhead when you turn around. So you start the tracklog at the trailhead, ride up the trail, and when you get to the end, you stop the tracklog and save it. Then you can reverse the route and follow it back to the trailhead. Mapping units are very nice in the respect that you can buy and download topo maps as your basemap so many features such as roads, trailheads and such may already be on the map.
However here is where memory becomes an issue. Most gps's only save so many routes/tracklogs, and a maximum of points along a tracklog/route as well. The more tracklogs and tracklog points you can have the more accurate you logs will be. Also they generally can be set so that if you run out of points in the default setting, it will auto extend the tracklog by putting more space between old points.
For example, the 76s will hold 1000 waypoints, and keep 50 routes with up to 125 waypoints per route, it will also hold 10,000 tracklog points. If you go to say a cheaper, etrex venture unit for example will only hold 500 waypoints, 20 routes of up to 50 waypoints, and 2048 tracklog points.
Routes are different than tracklogs. Routes are made up of waypoints, generally routes are done before you go somewhere from pre-existing data. I don't find routes very useful for biking because longer trails you cannot get a real idea of the trail shape by just having 50-125 waypoints over say 10-20 miles especially if you have a very winding trail. Since those waypoints have to be connected with strait lines you can end up missing a lot of trail.
Tracklogs are done automatically by the gps. Spacing the points as needed depending on it's memory. You can essentially have 10,000 points on a single trail if you want. Which gives you a much more specific and accurate display of the trail.
However if you want to record specific sites on the trail, such as the trailhead, a road crossing, a river crossing etc. and you do not have a topo map downloaded into a mapping gps you will have to manually enter the sites as you go.
Another thing you may find useful is if the gps has an electronic compass built in. Many gps's can only give you a compass heading if you are moving, those with a built in electronic compass can give you a compass bearing stationary.
What Todd said-
I really don't think memory is a issue. When you turn the tracking feature on you can adjust how often it "marks" a point. the more often, the better resolution your profile/track will have. Because I mostly use my GPS for biking and hiking, I set the timing to "most often". I left it set on that setting for a trip from Northern New Mexico to Salt Lake City, Utah, around town for several hours, during a funeral and all the way back. I had used about 70% of the total memory in over 1200miles of tracks, set to "most often"- the highest resolution. When I'm hiking/biking there is no way I could fill it up. If I want to save the track, just dump it to the computer, then you could add it to a map if you desire.
Mostly, it's pretty intuitive and a lot of fun. Just get one, play with it for a while and decide you need more gadgets to waste your time and money on. :D Someone had them on sale for about 400 clams this week, can't remember who though. TVsomething, five letters that made no sense to me.
Garmin Etrex Legend
I use the tracking feature most of the time. You don't even really have to use the backtrack feature when you return. The display reverses when you turn around. When you come to trail intersections, you just turn left or right or go straight ahead as shown on the map.
Discussion Starter · #20 ·
thanks for info
thanks for the info guys. it is very informative. I think I will buy the 76CS that has compass. I can afford toys while still single. I can't do it when I get married. The wife will kill me if I buy toys. :D
1 - 20 of 34 Posts
