The main pivot seems to have a 10mm hex outer shell, with the 5mm bolt located within it. When I stick a 5mm socket in there which is attached to my toque wrench, the body of the 5mm piece fits quite snugly on the 10mm shell, which means I have to turn the shell as well if I want to turn the 5mm bolt. Not a big deal normally but the shell requires more than 100 in.lbs. to turn, so I can't be sure that the 5mm bolt is torqued properly.
How do those of you who have done it, do it?
