There are probably other forums this would have fit it, but I chose this one since I'm going to mention some NorCal trails, and familiarity with those might be key in answering this question.
Last summer I went to Whistler for my first DH park experience. I was a bit too eager to be pretty proud of myself after three days, being able to corner fast enough to clear all the jumps on Crank It and most of them on A-Line. In retrospect, this may have had more to with how solid the corners were than any imagined skill I had.
Fast forward to now, I own a DH bike and go to Northstar with some regularity, but I still can't corner fast enough to clear every jump on Livewire, without pedaling in some places. I feel like I go too slow through the corners, but they are so dry (and rutted out sometimes), and any time I attempt to do it a little faster than usual, I feel my back end losing traction, and chicken out and plant my inside foot which ruins the whole turn but saves me from getting dirty. Three possibilities I can consider:
1) My technique needs to improve
2) I need to just go with the slide and not remove a foot
3) I need better tires
I know some people take the corners faster than me, I end up being tailgated every now and then. That never really happened at Whistler, even on harder trails like A-Line... but again the corners there were rock solid.
My tires are: Maxxis High Roller 2 27.5x2.4 DH TR 3c
I realize nobody can judge my technique in this thread, so #1 is up in the air (though obviously there is at least some room for improvement there).
For #2... I'm curious, is it normal to lose a small amount of traction even if you know your **** and have the right tires? Do you just hold on and try to keep steering?
For #3... please comment if there are better tires for Northstar like dryness.
