Pull the Fox Manual for the RP2 shock from the Fox website and go through the insturctions step by step for proper shock setup. It sounds like your shock pressure is a little high at the moment.
Sopwithcamel
Sopwithcamel
I am confused a bit, can you give some more info. I assume that you are feel the rear tire bounce around when you descend but only with rear brake on? Are you sitting or standing when this happens. The ML should be pretty neutral when braking.jasondub08 said:Need some help to get rid of the bounce. I'm 200lbs on my o8' ML1, I have a stock RP2 w/ the low tune @ 175 PSI.
Agreed... also, it could be a case of too much initial grab on the brakes.anvil_den said:I get a little of what u described when running the tire at a higher pressure than usual and/or when the tire is a little old and the knobs have started to harden.
"using low shock pressure (168) w/ full rebound. " definitely would get it to bounce a little more imo
