1 - 2 of 2 Posts
· Registered
Does anyone know how to properly size a coil spring for a coil-over rear shock ? I have a 2001 Specialized Enduro FSR, and there is too much sag. I weigh about 230# and want to replace the coil spring. Also, where can I find the proper spring ?
· Registered
you'll need to use a spring rate calculator and know some simple measurements.
link
specialized only archives back to 2002, but you can take the shock stroke measurement from your current shock and i'm assuming you know what the wheel travel is. if not, the 2002 version of your bike may be the same but i don't know that for sure. someone in the speshy forum may know or someone else may chime in here.
1 - 2 of 2 Posts
