This sounds about right,but the seals take ages to bed in.I assume you've put 30psi in both pos.chambers.If so just give it time,then start tweaking.Kelvin said:What do both the chambers do?
I am a 155lbs XC rider that rides in pretty rough trails. I have put 30psi in the pos. and 100 in the neg.
What do u guys suggest?
Cheers
Kelin
Ditto. You'll be surprise how dark that oil gets after the first 20 hours. Also, my Marathon came with too much oil and changing the oil was how I found out. After that, I got more travel out of it.The Jesmond Dingo said:P.S. It's worth changing the oil after about 20 hours bedding in.
