1 - 3 of 3 Posts
Do it for Deegan
Im going 1x10. My RD cable travels under the bottom tube of the frame under the BB then down the bottom chainstay. When I just removed the FD cable the guide that holds both the cables under the bottom bracket came loose. It is a piece of plastic that uses the cable tension to rest in a hole in the BB housing. I got it back on but its definitely not as secure as it should be. Where do I go from here?
Go pick up a screw-in guide from a shop, they should have them.
If that's a no go, you can grab a new version of whatever you had on there (probably had a split lug to snap into place), and if that doesn't work, run full length housing.
1 - 3 of 3 Posts
