Ok, I was talking with Ronnie awhile ago about pulling the rear triangle off to lube up the bearings and clean it up (5.5). The top came apart as planned (replaced it with a PUSH awhile ago) but the bottom I'm having problems with.
I removed my crank then the set screw and started unscrewing the black bolts on the nondrive side but they come out about a half an inch then stop. I tried to pull on them gently but no go. How do you get those two bottom bolts out?? I don't want to screw anything up.
thanks
me
thanks
me
