yep, what airwreck said. If you can get the bearings out without totally messing them up, you can take a pen-knife to pull the seals off, clean the bearings (dry out using air hose or something similar) and then repack them with grease.airwreck said:hey steve,
I haven't looked at a marz hub in a while but if its like a formula you should be able to slide the axle about half way in (or less maybe) and use it to lever the bearing out. Then you could replace or pull off the seals and clean and relube.
Steve, Didn't you say the hub is from '02 though?? If so, it seems like this might have been a long time coming and one rainy ride wouldn't make or break it. 4 years for a hub is pretty long, no?Steve71 said:Hey thanks for the info guys. I'll try to get some backup bearing before I mess with these ones. I wonder if there is something wrong with the seals though. Seems a bit odd that they would pack it in after just one ride in the rain.![]()
The hub was an 02', but it hardly got used at all (due to injury & buying a house) until this season. I wanted to build up another wheel with a Marzocchi hub so I could choose between two font tires without messing with the caliper alignment, but now I'm not so sure... maybe the seals rotted a little from sitting in the garage or something.ebxtreme said:Steve, Didn't you say the hub is from '02 though?? If so, it seems like this might have been a long time coming and one rainy ride wouldn't make or break it. 4 years for a hub is pretty long, no?
Cheers,
EBX
