1 - 6 of 6 Posts
Do it for Deegan
I just ordered the raidon through the upgrade program (thanks nick!) and I know that the fork can be set at 80, 100, or 120. Out of the box is 100mm and I wana set it to 120mm. Has anyone done this or know where to find step by step instructions? Also I want to put an O-ring on the stanchions if im going to have it disassembled anyway so does anyone know what size and where to find one? thanks in advance.
I'm pretty sure that fork has a pin/collar system for travel adjust similar to the Epicon.
Adjusting the travel on the Suntour Epicon X2 | MUDDYGOOSE
You'd have to pull it apart to confirm, but it should be similar and easily done. As for the o-ring, that fork should have a 32mm stanchion, so pick up an o-ring in 32mm or just slightly smaller. Any hardware store should have them.
1 - 6 of 6 Posts
