I've had to toss only a couple defective ones due to faulty valves in about 15 years of riding. When you buy them, look for thin or stressed rubber around the base of the stem, often this is a sign of a low quality tube. My defective ones were Fishers, I only buy Pyramid mostly anymore, which are made by Kenda and very affordable. I've actually had good luck with Performance tubes too.Ironbar said:What tool do I need to use and how do I do it? Thnx
Conti and Schwalbe tubes have removable presta valves. Other than those you can force the locking nut off the valve pin and let the core drop into the tube. After you put in the Slime, find the core, work it back into the valve stem and replace the nut.Ironbar said:thnx for the input bro but I'm looking to fill the tube with slime, and need to remove the core for that reason.
That sounds like the move, thanks for the scoopshiggy©®™ said:I would just get the Conti or Schwalbe tubes.
