Hi. My rigid 29er is working now (and working better than at first), but the brakes are suspect still.
I'm using XT m765 brakes with a 180mm A2Z rotor in front and the XT 160mm rotor in the rear. Initially, I had eBay generic/organic pads. These faded/smoked during my first decent descent (~500-600' maybe?). Since then, I rescuffed the rotors, cleaned with alcohol, and installed new shimano xtr organics. I bedded them lightly before riding trails. They're certainly working better, but on a recent & similar descent, the front began to fade a bit -- no burning smell, but the lever got a bit soft near the end, and the rear rotor looks like it was baked a bit (slightly tinted color since last descent.)
Other details: 195lb (geared up) rider on Northern California XC trails, some reasonably steep & long. Since it's fully rigid, I brake pretty regularly while descending. Wheels are respectably light 36 hole type.
I think the rotor diameter should be adequate, as I've managed very well with my165mm/145mm rotors on my 26er (older Hope minis are still working well). I'm open to trying a different composition pad, or replacing the front rotor with a more effective design if need be.
Questions: What do I need to do to get the optimal performance from these brakes? -- should the 180mm A2Z rotor work fine, or are they (A2Z rotors) less efficient than more expensive/different type rotors? Is the organic compound not ideal (felt good but seems prone to heating up too much)? Would a larger rear rotor solve my problems? With the somewhat narrow brake track, are these brakes destined by design to over-heat no matter the pad composition? Can I expect better performance from another pad maker/composition, and if so which one? Lastly, any rotor damage concerns by switching to a different pad compound? (This last question comes after the LBS showed me a few trashed rotors that were supposed to be the result of using metallic pads.)
Thanks for sharing your detailed experiences with these seemingly quality brakes.
105mm
105mm
