pacman said:
Every position = 12-3-6-9 o'clock?
Does not compute, if you turn it easily by hand then ?????. Your EBB or the stoker's? I don't know tandems (stoker has two chain rings?) but your result will be different with a one-person bike - guaranteed. BTW drag the rear brake to simulate a hill.
12 - 1:30 - 4:30 - 6 - 7:30 - 9 - 10:30. Could not do 3 without adding to the timing chain.
Tandem EBBs are at the front with a single chain running to the rear BB so it is just like a SS just on the left side.
The chain has slack on the bottom run when I run the EBB towards the back so the chain is not holding the EBB in place under load.
I did drag the rear brake, but it hard to keep from falling over. Jumped on the pedals, too, one and both together.
I need a small wrench to turn the insert and it rotates with little effort. If you can rotate the insert without using tools the tolerances are too loose.
My tandem has been ridden for many trail/dirt miles and the EBB has never slipped or creaked. I have stretched the timing chain and broken a couple, too.
