Hello everyone,
I was directed to this section of the forums after having no luck in the Brake forum or Specialized forum, and I'm looking for a frame building super guru wiseman or wisewoman who may be able to guide me (and many others) on the path of a quiet ride.
I'll keep the issue somewhat short and simple... (there are 150+ posts on this in the Specialized forum, so I am paraphrasing quite a bit)
All 2009/2010 Specialized Stumpjumpers affixed with hydraulic brakes (Avid Elixir standard) create a resonant frequency in the rear stays that transfers into the whole frame, causing vibration and a loud loud annoying howling noise from the rear brake. Specialized points the finger at Avid, Avid has been trying to come up with fixes, but it isn't the Avid brakes, it is the frame. This is proven because different makes/models of brakes have been tried, and they all do the same thing.
Here are some of the non-working fixes so far.....
-New solid non-vented G3 rotor from Avid (noise/vibration then came back)
-Switch from metallic to organic pad (noise/vibration then came back)
-Switch from organic to new metallic pads (noise/vibration then came back)
-Switch from new metallic pads to new organic pads (noise/vibration then came back)
-New vented G2 rotor from Avid (noise/vibration then came back)
-New, different brand rotor, any make/model at all (noise/vibration then came back)
-Upgrade from Elixir R to Elixir CR (noise/vibration then came back)
-Adjusting, truing, cleaning, balancing, reinstalling, checking, adjusting (noise/vibration then came back)
-9 trips to the LBS (noise/vibration then came back)
-New Shimano brake adapter (noise/vibration then came back)
-One user installed Formula RX brakes (noise/vibration then came back)
-One user suggests spraying expanding foam into the rear stays (not tested yet)
-One user wrapped the opposite chainstay in innertube (noise/vibration is muffled)
-One user ziptied lead fishing weights onto the rear brake caliper (noise/vibration is 90% eliminated)
Alright, so other than those last two fixes, another real fix doesn't exist. Avid has put together at least 4 different "fix kit packages" to send to the LBS, and they never work. Any amount of tweaking with the brakes themselves is useless. It is the combo is hydraulic brakes with this frame.
So why I'm here... I want to run two ideas by some of you who know materials and perhaps even a bit about vibration dampening.
1) Spraying the frame's rear stays with expanding foam (Great Stuff) - it will probably void the warranty, which sucks. Will this help? Could the expanding foam expand so rapidly that is cracks a stay?
2) Using Ti bolts for the rear brake caliper and caliper mount. My thought is that the different density/mass of Ti might not transfer this frequency into the frame, or at least deaden it a bit. Obviously aluminum fasteners are not an option here. I was also thinking about some other type of material to use for the washer for the caliper adapter. Similar to phenolic material used for car intake manifolds to prevent the cylinder head from transferring heat to the intake manifold... maybe there is a specific material washer that would help eliminate the transfer of vibration into the frame?
and
3) Do you have any other suggestions of how to eliminate this issue (without adding weight via inner tube or lead weights to the bike). These 09/10 Stumpjumpers may not be the nicest bikes in the entire world, but there are many owners like me, who had a budget, and bought the best bike they could afford. Putting lead fishing weights on a $2k bike is just ridiculous. Its not a fix, its a lead band aid.
Many people are dealing with this issue, and there no fix is in sight from Spec or Avid, so your help would be greatly appreciated!
Thank you and take care
and
