1 - 2 of 2 Posts
I bought the Mavic Crossmax XL at 2003, but I don't know if there are something that the shop where I bought forgot to give me to change on the axel.
I have a Fox Float and I'm thinking of changing to a RC Pike, but how do I change to a 20mm axel. Any photos?
it's simple. you pop out the quick release inserts on both ends of the hub. and you pop on the 20mm pieces.
i have the same wheelset 2003 version; the 20mm adaptor will run you 10-15 bucks..shipped..unless your shop wants to screw you.
it couldn't be any easier. no photos necessary. you may need to use some pliers to pull out the QR adaptors, just don't pinch it too hard; avoid damaging them. just enough to pull them out.
make sure you clean the adaptors and put a little grease on the inserts (QR or 20mm). if you really need a photo PM me, and i'll take a couple pics for you.
1 - 2 of 2 Posts
