1 - 12 of 12 Posts
Sorry if this comes across as a dumb question.
For all of my years cycling I've never had to change a cassette or anything along those lines before.
As I'm planning to change the cog on my GT Peace SS I'll need to buy some new tools.
What exactly do I need to remove this badboy?
Looks like a lock ring wrench and a chain whip should do the trick. The whip holds the cog in place while you turn the lock ring with the wrench. Park manufactures pretty cheap versions of each.
Discussion Starter · #3 ·
That's pretty much what I thought. Good to hear it from someone else though :)
My usual online store has the park lockring wrench for 33£, bit expensive.
These 2 should do the business, I hope.
http://www.billys.co.uk/english/group.php?prod=2idcwe-ecowhip
http://www.billys.co.uk/english/group.php?prod=2idbblrs
You can just grab the outside of the lockring with channel locks or similar. I've done so, and it works fine.
The chain whip is still needed. Or you can hold the pedal and use your chain, though that feels kind of abusive to the chain.
Hey man I'm not saying that this is the "best" way but if you want to do it tonight then you only need a channel lock pliers.
Leave the whole wheel and chain in your bike and keep it stable, It helps to have a friend. and put your legs in front of the pedals so that they don't freewheel backwards you're basically using your chain as the chainwhip. Open the channel locks wide enough to get a nice grab on the lockring and then just have at it. I think that I had a buddy help me the first time I did that.
You just need the channel locks to put it back on. If you do it this way then you might want to stop by the bike store if you're ever there for something else and have them tighten it up with the right tool just for peace of mind although i've never had a problem from this method.
Yes I have the right tools now and No I don't do it this way anymore and I know that a couple of people will freak out with this post but I'm just throwing it out there as an option.
Brandon
1 - 12 of 12 Posts
