thats what she said....Sparticus said:If it's tight, it's too tight.
--sParty
Is that +/- 1/4" (1/2" full range) or 1/4" total, up and down?Mike A. said:find the loose spot and aim for 1/4"
Why would you want to make the chain wear quicker?Firemedix911 said:If it is a new chain I set it tight. The chain will stretch and the be ideal. If it is a chain I've used for a while u should get the tool and check it every now and them so that it doesn't brake on you again and you cam swap it in time.
BM, when you say 1/2" deflection, is this the amount of "normal" sag 1/2 way between chain ring and cog, or are you applying some pressure and pressing down on the chain ?bad mechanic said:Why would you want to make the chain wear quicker?
Set the correct tension from the very beginning. I try and set 1/2" of total deflection (total up and down). I recently found out Cannondale recommends the same. A little looser is preferable to a little tighter, as tighter wears out equipment faster.
