My 2Bliss (brown) tape failed so I replaced it with gorilla tape per a few MTBR recommendations and installed a tire I ended up hating so I swapped to another. Ever since, my tire won't even hold air overnight. I'm assuming because I damaged/disturbed the gorilla tape. Is that expected to have to re-apply with every new tire? That's disappointing because I swap tires depending upon terrain.
In case it matters... the tire that is not holding air is a Maxxis Ardent 29x2.25 Exo TR on Roval Traverse wheels. I made sure that the line around sidewall near the bead is consistent (to confirm the bead is seated all the way around).
