I used to lube the stanchions using teflon lube and stuff like that , and it's USELESS.
If you put too much, dirt will stick to the lube and will make a thick gunk, so the fork will only work smoother the first 2 miles.
If you put just the exact quantity and wipe excess, the fork will work good less than two miles and the stanchions will be covered of dust again.
That's why I try to keep my stanchions clean, so the fork works quite good and if I want it smoother I just pump it a few times so the stanchions get cleaned an lubed by the oil inside the fork
