Try relube maintenance first
jimmy said:
Blur XC. I find I need to put air in every few days as I seem to lose 20-30 lbs after a few days. I pump it up to about 190 and then a few days later it is down to about 150 or so. How long do these shocks hold air? Is this normal? If it is leaky, how does one get it fixed? Send back to Fox? Send to PUSH? Or can my LBS fix it? Thanks.
First re lube (oil now?) the air seal. When they dry out they will loose air more rapidly.
Let the air out, unscrew the air sleeve. Use the recommended oil or lube on the slider seal and the seal near the chamber's threads. Screw it back together, air it up and see if it's better.
You shouldn't have to air it up more than about 10 psi more than once every 2 weeks or less often.
Follow the directions that should come with a new shock on user maintenance. You should be doing this maintenance every few months. Sometimes the shocks sit around a long time in some hot warehouse before getting sold and used and might just dry out some just from evaporation.
If it still leaks after normal maintenance, call Fox for an RA number. Fox will warrantee it. Or call your dealer you bought it from to warrantee it.
- ray
