How often do you replace the pivot bearings? (for FSR/FSRxc/Enduro)
This is kind of a novice question here
, but how often do you replace the pivot bearings (for FSR or FSRxc or Enduro)? Is there a general rule of thumb (ie. miles, seasons, etc)? Also, should I always replace all of them together, or more freqently (or less?) with the main-pivot bearings vs with the rear-triangle bearings?
It's just that... On my older '99 FSRxc (with MRP drop-out bearing kit), I didn't replace any bearings (before the frame cracked). On my newer '03 FSR, I already replaced one bearing (at the top of of seatstay on the drive-side) at 750miles a few weeks ago. Was that a random fluke, or should I also replace all the rest now?
Also, any good 'after-market' bearings that are better-quality & longer-lasting than 'stock' bearings (whatever kind Specialized may install at the assembly line)? I only know a few things about bearings from Rollerblading (ie. ABEC-5 vs -3, etc), but not much...
Thanks for the info in advance,
- PiroChu
- PiroChu
