In my case, none. I think I've gained 10 pounds since I started SSing exclusively 3 years ago. It might be due to my high fat content diet though...punk said:Assuming the same frame/fork and other componets, how much weight would I be dropping by ditching the gears?
Pretty easy to figure out. Look up online the weights of your particular brand of shifters, front derailleur, rear derailleur, chain rings, and cassette.punk said:Assuming the same frame/fork and other componets, how much weight would I be dropping by ditching the gears?
Thanks, I just did that and came up with ~2.5lbs by subtracting the weight of my deralliuers, shifters and cassette. Is that right? It seems like a lot.tlg said:Pretty easy to figure out. Look up online the weights of your particular brand of shifters, front derailleur, rear derailleur, chain rings, and cassette.
Then just fudge a little estimating for the shorter chain, shifter cables, front chainring, single rear gear, and gear spacer.
Should get you a good idea.
but not the high fat content diet. It's from the high hops and barley diet that always seems so prevelant with single speeding.Drevil said:In my case, none. I think I've gained 10 pounds since I started SSing exclusively 3 years ago. It might be due to my high fat content diet though...
That should be a good approximation. And yes 2.5 lbs could be correct depending on your components.punk said:Thanks, I just did that and came up with ~2.5lbs by subtracting the weight of my deralliuers, shifters and cassette. Is that right? It seems like a lot.
And, to clarify, I'm not looking to go SS for weight savings. The reason I'm asking is because I'm shopping for a new steel HT and considering going SS if I'm fit enough to do it.
I only ride in about three gears now, but one of them is my 22x28 granny that I can't imagine doing without on the hills around here. I guess I'm just wondering how a 2:1 ratio on a geared bike feels compared to a 2:1 ration on a SS.
I'm on a HT now, but bigger tires would certainly be part of the plan as my current ride won't swallow larger than 2.0 in the rear.pacman said:Going to a HT might tempt you to use bigger tires = added weight.
With a 22x28 you must be climbing sitting and spinning, practice climbing standing (middle ring) and fitness will happen.
then i would suggest getting 34 or 36 up front and getting a 20T king kog and perhaps order an 18T at the same time. i can climb anything a gearie can with 34-21 - faster - and if i cant they will be in granny and i'll be hiking up faster.punk said:I'm on a HT now, but bigger tires would certainly be part of the plan as my current ride won't swallow larger than 2.0 in the rear.
Yeah, I sit and spin, always have, especailly when traction is an issue. I'm not in bad shape, just used to having the bailout option, and pretty conditioned to sit and spin up rock, rooty, technical climbs. It's those kinds of things I'm worried about, cause I don't want to get off and push, I really like grinding up a steep technical hill.
good thing you checked into SS at least before trying it, sounds like it's probably not for you. But you did your research and gave it a shot, now you have the comfort of knowing that it just wouldn't be something that you'd enjoy. Or should even try for that matter. Better safe than sorry, I always say. Gears can be a wonderful, wonderful thing for certain people. I'm just glad we could save you some time, money, and sweat. You're probably not missing out on much anyways.punk said:Yeah, I sit and spin, always have, especailly when traction is an issue. I'm not in bad shape, just used to having the bailout option, and pretty conditioned to sit and spin up rock, rooty, technical climbs. It's those kinds of things I'm worried about, cause I don't want to get off and push, I really like grinding up a steep technical hill.
Gas Station Attendant: "I'm picking up your sarcasm."Hollywood said:good thing you checked into SS at least before trying it, sounds like it's probably not for you. But you did your research and gave it a shot, now you have the comfort of knowing that it just wouldn't be something that you'd enjoy. Or should even try for that matter. Better safe than sorry, I always say. Gears can be a wonderful, wonderful thing for certain people. I'm just glad we could save you some time, money, and sweat. You're probably not missing out on much anyways.
enjoy those gears!
HW
yeah, just giving ya a hard time.punk said:Tommy: "I'm picking up your sarcasm."
Richard: "Good thing, because I was laying it on pretty thick."
