Hi everyone
. How much is it for the base Lefty Max 140 upgrade to the SPV? I've got the base model but heard that it's possible to upgrade it. Feels good for now but would like more adjustability. Thanks for the help.
When I say TPC I really mean TPC+..edge said:
Something for you to think about....
The TPC upgrade from FFD dealer cost for the parts is $75 because you don't need a new rebound Assy. You can do that install yourself.
I just did a FULL SPV to TPC swap this wkend and changing the rebound assy is not very easy.
SPV parts are not cheap.
TPC is my prefrence but you can find many folks that pref SPV. I think it depends on where you ride. East coast = TPC. West coast = SPV.
Now where did I put that kevlar vest???
at the top of the travel, the TPC unit is more supple than the SPV.david8613 said:i am an east coast rider with spv, just wondering what am i missing out on that the tpc has over spv?
Are you saying you just SPVed it, or just got the bike? If you are a new owner, it's a very plush fork, take a little while and get used to it, if you mean you just upgraded, you may want to look at your spring rate, it may be too soft for your body weight.Thundermaxx said:It has a rebound adjust knob on top and that's it unless you include the internal spring preload.Are you saying this to David? I ask, cause there are more differences than that. All Leftys have a rebound knob on top. TPC+ offers rebound controls on top, and compression controls on bottom, SPV changes the bottom end, in that you have an air chamber which allows you to create a platform in the fork, making it more resistive to pedalling forces, and also has an adjustment to allow you to make it moe progressive and resistive to bottoming out.
What's the major differences between the two for a east to west preference?Damion hit this one on the head.
I just got the bike today and compare to what I've been riding it feels a little spungier. Even adjusted all the way. Felt good on the one test ride but it's raining here. Hit a few curbs but it's missing a little something. Thanks for the help.
I think he's a new owner of a FFD fork.MendonCycleSmith said:Are you saying you just SPVed it, or just got the bike? If you are a new owner, it's a very plush fork, take a little while and get used to it, if you mean you just upgraded, you may want to look at your spring rate, it may be too soft for your body weight.
When you look at the bottom of the lefty do you see a blue knob, red air input or nothing but a black nut?Thundermaxx said:sorry for the confusion. I just got the bike, not the Lefty. I'll ride it for a little while and see before I go changing to much. I think for now I can adjust the sag and fix it up some.
Ok, so it's confirmed then. You have a FFD compression dampener if your fork is a 2004+ Lefty 140 MAX.Thundermaxx said:Theres only a large black hex on the bottom of it.
You're all set for a TPC+ upgrade since you have a 2005 Left Max with FFD. Go for it!Thundermaxx said:It's an '05 prophet. I don't know if they changed between 04 and 05 or not.
Go for the TPC upgrade. It is well worth it.edge said:You're all set for a TPC+ upgrade since you have a 2005 Left Max with FFD. Go for it!
No special tools required AFAIK.sfprophet said:btw, I'm considering the FFD -> TCP+ upgrade as well. Thanks.
