Fox specifies 5mL of Float Fluid for air chamber. If you put more then the air spring gets more progressive.
I have 2013 Float32 29" CTD FIT fork and I would like to make it more progressive. I weight 105kg (230 lbs) in full gear and ride mostly XC and trail.
How much Float Fluid can one safely pour into air spring of this fork? I'm afraid that if I add too much the pressure at the end of stroke will be too high.
