MBR Mag puts Enduro Elite (Expert in euro talk) at 32# w/o pedals...that's with Nixon
First off, I guess the regular Deore stuff might be a full pound heavier. You could go to a site like speedgoat.com where they have an easily navigated menu of products and post the weights, so you could compare compentry to the gram there.
The info in the title comes from the new issue of MBR I happened to pick up. They reviewed the Elite version, which is basically the Euro Expert, and stated it being 32# w/o pedals with a Nixon Elite (stated by Mantitou to be 4.6Lbs) - so with the Fox 36 on the US version it would be about 3/4# heavier, so you were right on earlier...about 33lbs. Note that the bike I rode at the shop had silly plastic test pedals on it too, so that lighted it up. The Expert also has the version of the 36 that doesn't have the low end compression adjustment, so that would save some weight, although I don't know how much. I think I'm getting the Pro, but can't say at all for sure whether I'll really make good use of the low adj stuff. I don't even know how they factory set the regular R version, but I would bet its towards the plush side.
Anyway, this is more than you asked about, but you might notice this is the first thread I've posted to, so I don't have tired fingers. I've read this site for HOURS, so its good that I can supply something helpful to someone else.
-K
