Except lake snakes is a 7.8x2.25 and the ti spring isn't the right weight, length, size.TheDon said:Oh man, I hate imperial measurements. I much prefer metric.
We moved away from those in the UK long ago! Although we still use them in certain senarios.
According to the fabulous wikipedia;
There are 16 ounces in a pound.
A pound is 453.59g.
An ounce is 28.3495231 grams.
A quarter pound (or 4 ounces) is 113.398093 grams.
So if the shock body is about 14oz, that is about 396g. Which sounds about correct.
Lakesnake says his ti spring puts his shock a quarter pound more than the DHX Air 5.0, so that means his shock total should be about 450g+113g=563g (so the Ti coil weighs about 166g).
William42 says his shock with a steel coil comes in at about 960g so the steel coil weighs about (960g-396g) 564g.
Does that sound right?
It says on shop websites that Titanium is about 1/2 of the weight of steel, but these calculations (sorry guys, based on somewhat unreilable data) say about a 1/4 of the weight.
'IF' there is a lot of difference between steel and titanium coils. With a going price for a Ti coil at $200, sounds like a good idea to me!
Good thinking on the Ti spring.TheDon said:yeah, after a quick search through the various Ti vs Steel debates it seems that there is little point to getting Ti.
I might just swap over the DHX air for XC rides and then go to the Roco TST-r for DH days.
cheaper and will work out lighter. (just have to pump it up to stop it sagging to much)
Those #'s sound right on. There is a huge difference in steel vs. Ti springs in terms of weight. I bought two ti springs on E-bay. 275# and 300# for $25.00 and $60.00 respectively. Progressive suspension was selling a ton of them. I ride a Knolly Endorphin with a low leverage ratio of 2.4 and I weigh 140#, so I think the lower spring weights were easier to get a deal on. I was the only bidder for the 275# spring. After riding the coil, there was no going back to air, and a weight penalty of 4 oz.over a DHX-A is well worth it.TheDon said:Oh man, I hate imperial measurements. I much prefer metric.
A pound is 453.59g.
