I have an 7.875 x 2.25 DHX on my bike. My bike has 2 travel settings (6" and 7"). The stock spring has 2.3" (500lbs rate) of travel. I want to be able to use the bike well in both travel settings. I could solve this problem by getting a 400lbs x 2.3 spring in addition the spring I have now, or I could get a 2.6 x 400lbs (or what ever spring length comes stock with 2.5 stroke shock). The DHX has a lot of preload rings. If i could get the longer shock I could just simply preload it to 2.3 and get a 500lbs spring and back it out to get a 400lbs spring.
So, would it fit?
BTW: Does a spring with a higher spring rate weight more than a spring with a lower spring rate?
So, would it fit?
