My c-clip is a bit deformed... what should i do? can i fix it with a hammer and wrench? do i even need it?
what are these things refereed to at home depot?you can tap that back into shape with vice grips and hammer but it's best to use new ones.
or match one at hardware store...problem is thickness doing it this way
yeah it is sorta needed
yup, in the section with all the nuts and bolts should be ~3 drawers of clips to poke through. try to match thickness if that is an optionProbably "retaining ring" or "circlip"
